Electric Bilge Pumps installation
After owning my 30U for 22 seasons now, I finally have installed some electric bilge pumps… primarily because the boat is a solid hour-and-a-half drive or more from our home, instead of only 10 minutes. I have not had much of a water intrusion issue, except for the cracked cockpit drain hose that flooded the bilge maybe 18 years ago, but the distance to the boat and getting older has made me decide now was the time.
Installed 2 pumps - a 1000 GPH unit that is on an on-off switch to handle smaller amounts of water, and a 2000 GPH, along with an external float-switch, connected to an Off-Manual-Automatic switch with a built in alarm, to handle emergencies (or major bilge cleaning time).
As I didn’t want to secure the pumps to the bottom of the bilge with screws, I used 3M 4000 to fasten the base plates to the bilge. These actually had the opportunity to dry thoroughly as after they were put in place, I didn’t get back to the boat for over two weeks.
This past weekend I conncected the hoses and the wiring. Luckily both pumps use the same ID hose (1 1/8"), and to avoid drilling any new holes in the transom or hull, I found a ‘manifold’ that had a central tube that fits a 1 1/2" ID hose (the original/manual bilge pump hose) on either end, and two branch tubes that fit the 1 1/8" ID new hoses. Made the installation much easier! And yes (LLoyd Herman asked me this question at the Nonsuch diner luncheon this past winter - thank you for making me check this Lloyd!)) I checked the flow rate of the 1 1/2" tube exit and it could handle at least twice the volume of water that all 3 pumps (2 electric and the Whale Gusher manual) could flow simultaneously.
Wiring the small unit was basic, the larger unit a bit more complicated as it involved the external float switch and the automatic switch with the alarm and a few additiona connections. Both units are wired directly to the batteries, and fused individually at their respective batteries - the smaller unit to my start battery, and the larger unit to my house bank which is twice the size of my start battery. I figure this should give the automatic pump a fighting chance to run as long as possible until someone hears the alarm, or I can get to the boat. I also installed a device (thank you Bob Gerhman!) that will send me a text message if activated by it’s float mechanism. It is placed at the same level that the external float switch will activate the automatic pump.
Instead of mounting the respective switches inside the cabin, as I was hesitant to cut holes in any of that beautiful wood, I mounted both switches inside the starboard side lazzarette where the bilge blower and windlass switches, fuel gauge and a 12v plug are.
Some photos for your ammusement -
Best regards,
What’s this device that tells you the float was activated and by what means? Text , email carrier pigeon?
Hi Gary,
The device is the Water Level Alert by myspool.com. I chose the battery operated device as I try to attach as little to my batteries as possible as I dont have shore, wind, or solar charging systems (yet).
It connects to WiFi and I have it set to send me text messages. I receive a text about 20 or 30 seconds after it is activated. The unit is independent of the bilge pump float switch. It operates with it’s own float rising on rising water which triggers the message.
As long as the marina WiFi is operational it will work. I need to relook on how to reset to another WiFi if we travel to another location where we may be staying for several days, but I believe it is fairly easy.
Peter
Does the “manifold” have any kind of internal check valve(s) to keep one pumps discharge from back flowing into the bilge via another hose? Thanks!
John Gee - Tourmaline - NS 22 - #8 - Bolles Harbor, MI
Hi John,
No internal check valve. Installation guidelines from numerous sources say not to use a check-valve on bilge pump hoses, so I followed that line of thought. I spliced the manifold into the original bilge-pump hose near the transom thru-hull between the highest point of the hoses and the opening in the transom so it is pretty much a vertical drop to the thru-hull.
One of the photos posted shows the 3 hoses (1 off-white, 2 black) attached to the top of the manifold and the single off-white hose attached to the bottom of the manifold and then connected to the transom thru-hull.
This is an image of the manifold, though this one has two different sized branches, where the one I am using has two of the same size. They make a wide variety of size combinations.
Hope this helps.
Peter
Impressively clean bilge!
