exhaust smell in cabin
Good morning, we motored over from the marina to our mooring, it took about 45 minutes at 2000 rpms. I have a Westerbeke w27. When we got on the mooring I went down to turn off the batteries and I could seem exhaust fumes in the cabin. No blue smoke that I could see. I started the motor and checked the exhaust mixing elbow and the breather from the head to the air intake box. I could not see an obvious leaks they all appear intact. The water muffler is stainless steel and I could see no leaks on the connections.. There is a good amount of water and exhaust coming out that back. Any ideas on where to look or how to figure this out would be appreciated.
Peter Farley
Knot in a Hurry u30 #328
Keyport NJ
Maybe a dumb question but was there a following breeze?
Cowichan Bay B.C.
Wind was at a beam reach for most of the trip and on the bow at the end.
You might want to check the exhaust elbow. It might have corroded through and was leaking exhaust into the boat. Guess how It know?
Peter,
You said you checked the exhaust elbow, but normally the part of that coming out of engine block is surrounded by some kind of insulating wrap. That’s very hard to inspect.
I’ve attached a picture to illustrate. As you can see, this is a very corrosion-prone part, and also very heavy. The insulation in this case is the white fiberglass tape visible on the right, wrapped around the dry part of the exhaust between the riser and the cooling water inlet at the top, and held on with (rusty) wire.
I wonder if your exhaust smell might be coming from the hard-to-see area under the insulating wrap, or if the connection to the engine block (covered in this picture by the “st” in “exhaust”) might have just enough leakage for the smell to come through without necessarily emitting visible smoke.
I had this happen to my Universal 25xp, it took a bit of looking but it turned out it was the vent hose on the valve cover. It just “fell” off as there is no clamp on my engine. Hot oil fumes will come out. Just my experience.
Dennis
Poco 26U 1989
As I remember the crank case ventilation on the W27 is internal, no hose.
My w27 has a vent hose and I discovered it was disconnected leading to odor.
Don Ringsmuth
Selkie 30 Ultra 425
East Hampton, NY
Also check for leaks around the exhaust manifold.
I recently overhauled my engine. Mark is correct about checking the exhaust manifold. In removing the manifold on my W27, the nuts were challenging to remove (hard to get to), and I found most to be no better than hand tight. Either they had loosened over time, or someone previously had not been able to re-tighten them due to oversized fingers! The gasket on the manifold to the exhaust riser should be checked as well. I made this particular gasket out of exhaust manifold gasket sheet that I purchased from Napa. If you do remove the exhaust manifold itself, you will need to purchase that exhaust manifold gasket and be sure to clean the surfaces for the new one.
Neville Weir
Cat Sass 30U
Vancouver, BC
Following wind.
Bill W
Coddiwomple 324 114 East Jordan.
Well I found the source of my problem. The injector closet to the front of the motor is leaking compression from the seal.
This caues soot and exhaust fumes to be blown into the engine room. Now I have reaplced the riddle with a puzzle, how to get the injector out.
I will ask in a seperate thread
Peter Farley
Keyport NJ
