30C window size info needed
Hello, I wonder if anybody has the window dimensions of Nonsuch 30C (1984 model)? I am planning to custom- made the curtains and forgot to measure the window size before the winter . My boat is now on land in Canada and I am out of the country at the moment. Any helpful info is highly appreciated . Thanks
Shirley Cheung
Shamrock
Nonsuch 30C 1984
Whitby, Ontario
The original ports holes were manufactured by Atkins & Hoyle that are located near Napanee, ON. They still make the port holes. Below is a link to that item which has the original dimensions indicated. Copy and paste it in your search engine.
Stephen Marinelli
SUNSHINE N30U #271
Burton, New Brunswick
The cabin top side windows on my 30U are about 14"w x 8"h, including the frame. The two curtains on the window are each 12"w x 10"h.
Hope that helps.
That sounds about right. But always add an inch or so to the outside dims to have a good overlap for the morning light shining in to say THIS IS A NEW DAY!
Just my 2c
Hi Don,
Thank you sooooo much! Really appreciate for your info !
Shirley
