Is your Nonsuch leaking?
In my opinion multiple lawyers compliment any boat.
I know a Judge that can add even more class…
I hope I’m not over simplifying a fix for this but I had leaks that have been drastically reduced (still trying to find 1 water ingress on the cabin top) with the use of FLEX SEAL. I applied a generous amount of flex seal paste around the windows and no more leaking. I’ve done the same in several other areas and same result 2 years in. I also use it around crazed areas to prevent water soaking in. As stated I still have to find the final cabin top leak.
David Godfrey
NS30C #145 Thursday’s Child
RNSYS Halifax Canada
For those annoying leaks that you can’t find, I’ve had amazing success with Captain Tolley’s creeping crack cure.
Yep!
